Automatic case packer
The XpressPack automatic case packer is designed to run high volumes of cartons in a single-layer, single-row configuration.
The XpressPack automatic case packer is designed to run high volumes of medium-to-large sized cartons in a single-layer, single-row configuration. XpressPack’s high speed operation handles up to 10 cases per cycle. It is ideal for the beverage market and is also a good choice for cereal and laundry detergent boxes, as well as foils and plastic wraps, and parchment paper. The XpressPack is perfect for standard five-panel folded carton, glue-end styles. Designed for simple setup and changeovers, the XpressPack can accommodate carton sizes ranging from 8-in. wide by 8-in. long through 24-in. wide by 28-in. long. Special machines for other sizes can be custom-engineered. Heavy-duty welded steel frame construction provides durability and long life, while the dual vector drives eliminate the clutch-brake system.
WSI Global
https://wsiglobal.com/express-pack/
