Anti-seize lubricants
Permatex anti-seize lubricants protect mated metal parts against corrosion, rusting, galling, friction and seizing. They also reduce wrench torque, easing the assembly and disassembly of threaded, slip-fit, and press-fit connections. The lubricants are an inert blend of heavy-duty aluminum, copper and graphite lubricants in a petroleum base and are capable of withstanding service temperatures f...
12/01/2006
Permatex anti-seize lubricants protect mated metal parts against corrosion, rusting, galling, friction and seizing. They also reduce wrench torque, easing the assembly and disassembly of threaded, slip-fit, and press-fit connections. The lubricants are an inert blend of heavy-duty aluminum, copper and graphite lubricants in a petroleum base and are capable of withstanding service temperatures from %%MDASSML%%60 to 1,600 degrees F without hardening or evaporating. Copper-free Permatex nickel anti-seize lubricant is designed for use with stainless steel, titanium and nickel alloys and withstands service temperatures to 2,400 F. Permatex copper anti-seize lubricant is a premium lubricant that provides good electrical conductivity, withstanding service temperatures from %%MDASSML%%30 to 1,800 degrees F. Permatex food-grade anti-seize lubricant is a nondrying, nonmetallic, PTFE-fortified, synthetic-based formulation for lubricating machine parts, press fits and shafts as well as threaded connections.
Devcon
www.devcon.com/89
October 2018
September 2018
July/Aug
October 2018
August 2018
October 2018
September 2018
