Air treatment products
Refrigerated and desiccant regenerative dryers and filters
Depending on the application and dew point requirements refrigerated and desiccant regenerative types are available. Refrigerated dryers are available in four different configurations, including non-cycling models, digital cycling models, cycling models, and high temperature models. Desiccant regenerative dryers, ideally suited for outdoor compressed air piping or operations that require dew points as low as -40°F (optional -100°F), are available in four different configurations: modular, heatless, externally heated, and blower purge. Filters, which are designed to protect plant equipment and processes while improving product quality and for applications, cover a wide range of uses from general purpose to the most critical levels of food and pharmaceuticals.
Sullair Corporation
