Air-powered vacuum
February 21, 2011
The Model 860/02 is perfect for managers who want to eliminate drum handling, and collect and discharge their powders in a safe, dust-free & convenient way. The Model 860/02 uses an air-powered vacuum cover with manual pulse-jet filter cleaning and non-stick filtration that captures 99.9% of particles as small as 0.5 microns. The rugged portable frame includes a collection hopper with automatic discharge valve and polybag loading accessory. When the vacuum is turned off, the collected powder automatically discharges into off-the-shelf static-conductive polybag.
VAC-U-MAX
www.vac-u-max.com
