4-port isolated USB hub
The USB-104-IHUB is ideal for factory automation, hospital and medical, energy management, military/mission-critical, transportation, security systems, and process monitoring applications.
The USB-104-IHUB is a small medical/industrial/military grade hub that features Tru-Iso™ signal isolation up to 4 kV, extended temperature operation (-40 C to 85 C), high retention USB connectors, and an industrial steel enclosure for shock and vibration mitigation. It is ideal for applications including factory automation, hospital and medical, energy management, military/mission-critical, transportation, security systems, and process monitoring. The unit features advanced EFT, lightning, and ESD protection at 20 kV on all signal pins, two power input connectors, and LED indicators for power and fault conditions for each downstream port.
ACCES I/O Products, Inc.
