3,900-watt LED work area string light set
The 3,900-watt LED work area string light set for general work areas.
The 3,900-watt LED work area string light set for general work areas. This unit is UL1598 approved and ideal for inspection activities and temporary illumination in wet locations. A special heat dissipating design in conjunction with LED technology allows each fixture to achieve an excellent 60,000 hour rated lifespan. This LED string light set is IP67 rated, dust-proof, and protected against high pressure jets and temporary submersion. This string light set can be separated centrally, giving operators the ability to utilize only 13 lights when desired. This LED string light operates with 208-277 volts AC without any modifications. The aluminum body and LED lamp gives this string light set excellent durability and resistance to vibration and impacts.
Larson Electronics
www.larsonelectronics.com
