Level winding drive
Rolling ring level drives enable users to spool cable with specific spacing between rows.
Rolling ring level drives are designed to enable users to spool cable with specific spacing between rows. A set screw is inserted into one of both ends of the drive housing, allowing measured spacing of spooling rows with no complex electronics or programming needed. Machine designers will find the set screw option an effective, low cost solution for spooling applications that require spacing of rows on the take-up reel.
Amacoil Inc.
www.amacoil.com
