Electronic indexer
The rotary indexer product set is a fully programmable, direct-drive solution that provides precise, repeatable and flexible electronic indexing in a compact package. Quickly and easily programmed to go in almost any direction at most speeds and angles, the indexer set incorporates precisely matched components to ensure interoperability and optimized performance, ease of system selection and or...
The rotary indexer product set is a fully programmable, direct-drive solution that provides precise, repeatable and flexible electronic indexing in a compact package. Quickly and easily programmed to go in almost any direction at most speeds and angles, the indexer set incorporates precisely matched components to ensure interoperability and optimized performance, ease of system selection and ordering and quick, easy system commissioning. Users can update the motion sequence to satisfy their application needs as their manufacturing processes change. The indexer can rotate both clockwise and counter clockwise to achieve a short cycle time and increased throughput. Index times are programmable, and no homing is required as absolute position feedback maintains position, even under power cycling.
Danaher Motion
www.danahermotion.com
