Electric actuators with thermally-bonded powder-coat
The Series 92 electric actuators feature a die-cast aluminum alloy with a thermally-bonded powder-coat.
The Series 92 electric actuators feature a die-cast aluminum alloy with a thermally-bonded powder-coat. This combination NEMA Type 4X, 7 and 9 enclosure is bolted together in two sections by eight M8 hex-head cap screws and fitted with an O-ring between the two halves, allowing the Series 92 to weather harsh and hazardous environments. It also features a permanently lubricated gear-train and hardened steel spur gears. Two end-of-travel limit switches are mechanically set via adjustable cams for open and close positions. Accessories such as 4-20 Ma positioners, single and double extra limit switches, heater and thermostat, and two-wire control relays are all available factory installed and calibrated in the actuators. The Series 92 electric actuators will be on display at the 2016 Offshore Technology Conference in Houston.
Asahi/America, Inc.
www.asahi-america.com
– Edited by CFE Media. See more Oil & Gas Engineering products.
