XPS SIP cartridge seal cuts downtime
XPS pump seals reduce downtime, power consumption and operating costs. They are an alternative to mechanical seals and compression packings. Seals are replaced in seconds with SIP (serviceable in place) technology. Since there are no brittle faces, these seals are very tolerant of process upsets and dry running.
XPS pump seals reduce downtime, power consumption and operating costs. They are an alternative to mechanical seals and compression packings. Seals are replaced in seconds with SIP (serviceable in place) technology. Since there are no brittle faces, these seals are very tolerant of process upsets and dry running. No seal flush is required. Seals can be used up to 1,600 fpm, 300 F and 150 psi. Klozure Dynamic Seals : www.klozure.com
TO VOTE, WRITE 94 ON BALLOT
For more information, write 94 on card
