Wire/cable pulling lubricant brochure
Velocity, an ultra-low-friction cable pulling lubricant, is highlighted in a recent brochure. Velocity helps contractors achieve pulls in electrical, telecommunications and data applications. The brochure also features Aqua-Gel, ClearGlide and Yellow 77.The guide’s “Select-A-Lube” enables electricians to select the right lubricant for their application, based upon the type of job, construction, indoor or outdoor location, temperature and length of pull.An interactive, on-line version of Select-A-Lube, featuring a lube quantity calculator, is available online at https://ideal.sdafiles.com/ .
Ideal Industries, Inc.
www.idealindustries.com
