White, blue wire duct
White and blue wire duct, with UL and CSA approvals, are now available.
White and blue wire duct options are now available, with UL and CSA approvals, and are made from PVC material with a V0 inflammability rating as per UL 94. The white and blue wire duct has the same features as the gray and halogen-free duct. The flexible fingers will not snap when the user runs wire through them. The wire duct features a notched score line that eliminates the need for notching pliers to break off the fingers. However, breaking the wall will require the use of a cutter. The cover’s contour allows it to snap on easily and fit securely. The duct and cover are available as a complete set, or the covers can be ordered individually. The wire duct ranges in size from 25 mm to 120 mm to meet the needs of a variety of applications and is available in two-meter lengths.
Phoenix Contact
www.phoenixcontact.com
