Welding fume extractor
The Mini Flex welding fume extractor is a portable, high-vacuum, low-volume system designed for the removal and filtration of welding fume. It features a four-stage filtration system that had a filtration capacity of 99.9% and requires less frequent filter maintenance. The Mini Flex can be used in confined spaces and other areas where a larger unit would not fit.
The Mini Flex welding fume extractor is a portable, high-vacuum, low-volume system designed for the removal and filtration of welding fume. It features a four-stage filtration system that had a filtration capacity of 99.9% and requires less frequent filter maintenance. The Mini Flex can be used in confined spaces and other areas where a larger unit would not fit. The Lincoln Electric Company : www.lincolnelectric.com
TO VOTE, WRITE 103 ON THE BALLOT
For more information, write 103 on the card
