Webcast: Energy Management Decisions: Repair or Replace Electric Motors?
A perennial question in plant maintenance circles is whether it's better to repair or replace an electric motor that has failed. Will a repaired motor retain it's efficiency rating? Learn how to better understand the key criteria to consider when facing this decision, and learn about a new accreditation program relating to the repair of electric motors.
By Plant Engineering Staff May 28, 2015
A perennial question in plant maintenance circles is whether it’s better to repair or replace an electric motor that has failed. Will a repaired motor retain it’s efficiency rating? Join the webcast to better understand the key criteria to consider when facing this decision, and learn about a new accreditation program relating to the repair of electric motors.
Among the information included in this webcast:
  • What are the key factors to consider when determining to repair or replace a failed electric motor?
  • Can a repaired motor maintain it’s reliability and efficiency rating?
  • How does ANSI/EASA AR100-2010: Recommended Practice for the Repair of Rotating Electrical Apparatus support plant maintenance practices?
  • Can maintenance managers be assured that motors are repaired following this ANSI/EASA Standard?
Speaker:
Tom Bishop, P.E., Senior Technical Support Specialist, Electrical Apparatus Service Association (EASA)
Moderator:
Bob Vavra, Content Manager, Plant Engineering, CFE Media
Author Bio: Since 1947, plant engineers, plant managers, maintenance supervisors and manufacturing leaders have turned to Plant Engineering for the information they needed to run their plants smarter, safer, faster and better. Plant Engineering‘s editors stay on top of the latest trends in manufacturing at every corner of the plant floor. The major content areas include electrical engineering, mechanical engineering, automation engineering and maintenance and management.
