Continue to Site
Walkie straddle stacker
The Crown ST 3000-25 Series walkie straddle stacker can handle up to 2,500 lbs. and is designed for environments with tight spaces, such as grocery and retail
January 29, 2014
The Crown ST 3000-25 Series walkie straddle stacker is capable of handling up to 2,500 pounds and working in environments with tight spaces, such as grocery and retail. The durable, cast aluminum control handle features advanced ergonomics so operators can effortlessly perform any function necessary. A brake override feature ensures accurate maneuvering when the handle is in the near-vertical position. This allows the stacker to easily turn in tight quarters while reducing the risk of damage to the truck, load and facility. The Crown ST 3000-25 comes with an onboard charger that allows its 24-volt powered lift and travel system to be charged anywhere in the facility.
Crown Equipment Corporation
www.crown.com
