Voltage testers
The ET60 and ET250 voltage testers use standard replaceable test leads and can test GFCI-protected circuits.
By Klein August 14, 2017
Two new voltage testers use standard replaceable test leads for added convenience. Courtesy: KleinTwo new voltage testers use standard replaceable test leads for added convenience. The ET60 voltage tester requires no batteries as it measures ac/dc voltage up to 600V in electrical circuits, outlets, light fixtures, and anywhere else ac/dc voltage testing is required. The ET250 voltage and continuity tester incorporates an LCD display, measures ac/dc voltage up to 600V and can test GFCI-protected circuits.
Klein Tools
www.kleintools.com
