Vertical order picker
EKS 110 Vertical Order Picker facilitates order picking with four lift-height options.
EKS 110 Vertical Order Picker facilitates order picking with four lift-height options. The platform/load section can be raised to 118 inches, allowing items to be picked up from heights up to 15 feet. Its lifting capacity is rated at 2,200 pounds, which allows it to pick pallets or crates longitudinally or crosswise. The truck’s drive technology provides high torque under any load, and the motor features no carbon brushes, brush springs or armature commutator to replace.
Jungheinrich Lift Truck Corp.
