Venturi cartridge series
Cartridge series replace failed or clogged multi-stage pumps to maximize productivity and minimize downtime.
The RTM venturi cartridge series is designed for the packaging industry. RTM cartridges replace failed or clogged multi-stage pumps to maximize productivity and minimize downtime. Vaccon’s single stage cartridges allow dirt, dust and debris to pass through the pump without clogging. RTM cartridges thread directly into existing multi-stage vacuum pumps and vacuum grippers, generating high internal velocities that carry dirt through and out of the pump. Multi-stage pumps operate using flap valves that clog from ingested debris. The RTM Series are manufactured in 11 different performance levels.
Vaccon
