Variable-speed combustion blowers
The Nautilair Series 12.3-inch variable-speed brushless DC blowers introduce high-performance solutions for high-output gas-fired burner systems.
The Nautilair Series 12.3-inch variable-speed brushless DC blowers introduce high-performance solutions for high-output gas-fired burner systems. The pre-mix blowers are engineered to deliver a measured air/fuel mixture for optimized combustion and reduced nitrous oxide and carbon monoxide emissions. The blowers provide alternatives to conventional fixed-speed or two-speed blowers, intake damper systems on fixed speed blowers or inverter-driven variable-speed blowers. Typical applications include commercial and residential boilers, hot water heaters, furnaces, foodservice equipment, kilns and fuel cells, among others. AMETEK Technical & Industrial Products, a unit of AMETEK, Inc. www.ametektechnicalproducts.com
