Vacuum lifter
The high-capacity vacuum lifter and tilter features a steel welded frame with two hydraulic cylinders that handle steel fabrication loads up to 10,000 pounds.
By Plant Engineering Staff July 17, 2008
The high-capacity vacuum lifter and tilter features a steel welded frame with two hydraulic cylinders that handle steel fabrication loads up to 10,000 pounds. The cylinders can rotate remotely from horizontal to vertical positions. The unit contains up to eight vacuum pads measuring 19×25 inches each. The unit also features a built in vacuum reservoir, a check valve, vacuum gauges, and safety audio-visual alarms.
Anver Corp.
www.anver.com
