USB data logger for temperature measurements
This USB data logger is capable of measuring and recording more than 32,000 temperature readings, has a long-life lithium battery and is IP67 rated.
December 3, 2009
The EL-USB-1-PRO is a high temperature USB data loggercapable of measuring and recording more than 32,000 temperature readings from-40 F to 257 F. Housed in a waterproof, stainless steel enclosure that protectsthe logger from corrosion, impact and moisture, the unit is rated to IP67 /NEMA 4X standards and can be used in extremely hostile environments. The datalogger is supplied with a long life, replaceable lithium battery that allowslogging for up to three years.
Free configuration and download software is provided with
each data logger. Simply plug the logger directly into a USB port and use the
EasyLog software to choose a logger name, set a sample rate, program high and
low alarms and select immediate or delayed logging start. The unit can then be
placed in the chosen logging location. When logging is complete, plug the data
logger back into the computer’s USB port and download the data, which can be
graphed, printed or exported to other spreadsheet applications.
Lascar ElectronicsInc.
www.lascarelectronics.com
