Plant Engineering – December 2000
MATERIAL HANDLING F eature: Updating crane systems for optimal performance
Sidebar 1: Analysis of a crane system Greg Miskowiec, General Product Manager, CraneMart, Amherst, NY
Key concepts
Crane systems are usually updated to increase capacity or match changing production requirements.
The system consists of a hoist, trolley, and crane bridge .
Type of bridge, operating envelope, environmental conditions, and performance parameters must be determined.
An overhead crane bridge can lead a long, productive life. For example, an electric crane built for the Cheyenne Railroad in 1884 is still in operation. Longevity of the overhead crane bridge is extremely important because it is often the most expensive part of the system.
This article offers several tips on how to update the crane bridge system by replacing components, such as the hoist, controls, and electrification.
When to update The two most common reasons for updating an overhead crane system are to increase capacity and accommodate changing requirements of production or other processes.
Process machinery is becoming increasingly faster, while many end products are getting heavier. Perhaps the 3-ton steel coils produced in the past now weigh up to 5 tons because of production changes. Rather than replacing the whole crane system to handle the load increase, it may be possible to install a higher capacity hoist and upgrade the bridge.
Faster throughput and other changes in production flow also affect system requirements, such as speed and duty cycle. The hoist may now need to lift the prescribed load once every 5 min, rather than once every 60 min. Weight of the load, number of times the hoist works per hour, and number of hours or shifts per day all contribute to determining equipment needs.
Upgrading to a hoist with a higher service capacity and faster hoisting speed that can handle more cycles per hour effectively improves the whole overhead lifting system.
Consider a technology upgrade The need to replace a hoist provides an excellent opportunity to think about additional ways to modernize the crane system. Recent developments in control technology and improvements in electrification are worth examining.
While older magnetic contactor controls abruptly switched power to the hoist on and off buffered by resistors, newer products employ variable frequency drives that ease power to the hoist motor through programmed acceleration and deceleration ( see illustration ). There is no surge of electricity so the motor runs cooler, lasts longer, and experiences fewer problems. This kind of control also avoids shock loading to the drive train and gives better load control, because hoist speed is ramped up slowly and smoothly and loads are positioned more precisely with less swing.
Typically, older hoists are controlled by a pushbutton station that hangs from the hoist or bridge. Some crane systems employ cab controls, with the operator sitting in an overhead compartment that rides along with the crane. Obviously, these types of controls limit the operator’s mobility. Radio systems where the operator has the transmitter in hand and can control all crane motions from almost anywhere in the bay may be a better choice.
It might also be wise to modernize with a festoon cable system. Some old cranes use bare copper wires or steel angles to carry power to the hoist and trolley. (OSHA now prohibits exposed high-voltage systems like these on new equipment.) Festoon cables provide a safer, more consistent power supply.
Specifying a new hoist A manufacturer needs detailed information in order to supply the right hoist. Whether custom or straight from the catalog, the hoist must perform satisfactorily and accommodate the layout, confines, and obstructions of the work area.
Here is a checklist of questions the specifications should answer, along with some examples of how the answers might influence the type of hoist chosen. Giving each manufacturer the same data helps evaluate competitive bids.
What type of crane bridge will the hoist run on—single or double girder? This decision determines whether the hoist should be a monorail type running on the bottom flange of a single girder bridge beam, or a top-running model moving on top of a double-girder crane.
If it is a single-girder crane, what type of beam will the hoist be suspended from? What are the depth, flange width, and flange thickness of the beam? This information is required to assure that the hoist’s trolley fits on the beam.
If it is a double-girder crane, note the size, type, and center-to-center spacing of the rails the trolley will run on. In addition, what is the width of the bridge girders, and what is the distance between their inside edges? These dimensions are needed to assure that the wire ropes of the hoist won’t rub against the edges of the girders at the high or low points of the lift, and that the trolley will fit on the rails and clear the bridge girders.
What is the envelope that the hoist will pass through? Specify the size and location of any obstructions in the hoist’s path, such as lights, pipes, ventilation systems, sprinkler heads, roof trusses, etc., to make sure the new hoist clears them.
What type of environment will the hoist operate in?
– Is the hoist indoors or outdoors? Equipment used outdoors needs to be weatherproof so that water and moisture won’t damage the electrical components.
– Is it outside in snow country? If so, weatherproofing, plus shielded cross conductors to prevent ice and snow buildup that can cause sagging or breakage, are required.
– Is the environment dusty? Control panels need to be dusttight.
– Is it a high-heat environment? If the hoist will be used in a place where the ambient temperature is high—such as a foundry, paper mill, or hot climate—this may determine the type of motor or controls to use. If the hoist is exposed to radiant heat, shields for the motors, controls, and drive trains are required.
– Is the moisture content high? Condensing moisture in extremely humid climates can damage motors. Use moistureproof controls and motors, possibly with heaters.
– Is the atmosphere corrosive? Hoists used where etching, cleaning, plating, or pickling processes are performed; or where they are exposed to acid baths or caustic fumes, need special paint and motors, as well as control enclosures, to prevent corrosion.
– Is the environment explosive or hazardous? Explosionproof controls, motors, and brakes are essential where the hoist may be exposed to explosive gases, fibers, or dust.
– What is the altitude? Thin air at altitudes above 3100 ft is less efficient at keeping motors cool. Motors with cooling fans or larger frames may be required.
– Are there any other environmental considerations? For example, hoists used in the tropics may need protection against fungus, rodents, and insects that can damage electrical components.
What are the lifting speeds or throughput requirements of the application?
What is the duty cycle? This factor determines how heavy and rugged the hoist needs to be. A hoist that is not tough enough for the job provides poor service and wears out more quickly. Keep in mind that, according to ASME specs, the average load the hoist carries should be no more than 65% of its rated capacity.
This duty cycle information should be provided:
– Number of lifts/hr
– Number of hoist motor starts/lift cycle required to raise, lower, and position a load
– Maximum weight of load handled
– Average weight of load handled
– Number of hours/shift hoist is used
– Shifts per day
– Days per week.
