UHF RFID system
SIMATIC RF 600, an RFID system that operates in the UHF band, is designed for logistics and distribution. The system has three communication ports: Ethernet, RS-422 and RS-232. It transmits data to IT, ERP and SCM systems, to SIMATIC PLCs, or to PCs. The antenna is designed for IP65 and can be mounted on walls or frames.
SIMATIC RF 600, an RFID system that operates in the UHF band, is designed for logistics and distribution. The system has three communication ports: Ethernet, RS-422 and RS-232. It transmits data to IT, ERP and SCM systems, to SIMATIC PLCs, or to PCs. The antenna is designed for IP65 and can be mounted on walls or frames. Up to four antennas can be connected to the read/write device.
Siemens; AMD Div., Discrete Automation Group : www.sea.siemens.com/automat
