Tubing
I-flex PVC tubing and connectors provide electrical wire protection outside the control cabinet and is suitable for use in both indoor and outdoor environments. The tubing maintains its tensile strength and withstands temperatures from -4 to 140 degrees F. It comes in 98-inch rolls and is available with straight or 90-degree connectors.
By Plant Engineering Staff September 30, 2007
I-flex PVC tubing and connectors provide electrical wire protection outside the control cabinet and is suitable for use in both indoor and outdoor environments. The tubing maintains its tensile strength and withstands temperatures from -4 to 140 degrees F. It comes in 98-inch rolls and is available with straight or 90-degree connectors. The tubing provides NEC and UL-approved protection against water, oil and other damaging liquids and comes in sizes ranging from 3/8 inch to 2 inches.
AutomationDirect
www.automationdirect.com
