Truck leveler
The Z-Deck truck leveler allows trailers to be serviced at or above dock height with a Z-shaped deck design that helps minimize the slope of the lifting surface.
By Plant Engineering Staff June 15, 2008
The Z-Deck truck leveler allows trailers to be serviced at or above dock height with a Z-shaped deck design that helps minimize the slope of the lifting surface. The leveler has a 158-inch profile while collapsed, and a dual-wheel guide provides consistent trailer alignment at the dock. The leveler does not require a below-grade pit and improves safety by keeping tires even to the surface, reducing the opportunity for trailers to move away from the dock.
Rite-Hite Corp.
www.ritehite.com
