Transmitter provides accurate readings
Model 1500 Coriolis transmitter for filling and dosing applications provides accurate and repeatable mass flow, volume flow, density and temperature measurements in real time. The transmitter measures liquids with entrained air and suspended solids, as well as gases and aerosols. Unit is compatible with a wide range of sensors, including hygienic models for CIP, SIP and EHEDG certification.
By Staff November 1, 2005
Model 1500 Coriolis transmitter for filling and dosing applications provides accurate and repeatable mass flow, volume flow, density and temperature measurements in real time. The transmitter measures liquids with entrained air and suspended solids, as well as gases and aerosols. Unit is compatible with a wide range of sensors, including hygienic models for CIP, SIP and EHEDG certification. Emerson Process Management, Micro Motion div. : www.micromotion.com
TO VOTE, WRITE 90 ON BALLOT
For more information, write 90 on card
