Torque sensor
The 4503A series torque sensor has two separately calibrated test ranges to simplify rotary device testing allowing a single instrument to sense specimen operating ranges and additionally sense the torque peaks above nameplate levels encountered in typical test sequences.
By Plant Engineering Staff December 1, 2008
The 4503A series torque sensor has two separately calibrated test ranges to simplify rotary device testing allowing a single instrument to sense specimen operating ranges and additionally sense the torque peaks above nameplate levels encountered in typical test sequences. Where engines, pumps and turbines are cycled, torsional vibration and torque peak into the capability of the higher instrument range. Integral measurement electronics use digital signal processing and provide outputs of
Kistler Instrument , www.kistler.com
Related Resources
