Tooth clutchers
Nexen 5H Series tooth clutches deliver fast, no-slip engagement for washdown applications where high torque is required. The enclosed tooth clutches provide positive torque transmission and feature a nickel-plated exterior and rotary seal to withstand wet, corrosive environments common to food and beverage processing applications.
By Plant Engineering Staff May 1, 2009
Nexen 5H Series tooth clutches deliver fast, no-slip engagement for washdown applications where high torque is required. The enclosed tooth clutches provide positive torque transmission and feature a nickel-plated exterior and rotary seal to withstand wet, corrosive environments common to food and beverage processing applications. The 5H Series Tooth Clutch models offer positive, single-position tooth interface for synchronized engagement.
Nexen Group
www.nexengroup.com
