Tight moves
Problem: A piece of equipment close to a column or other stationary object needs to be moved closer. The spacing is too close to use a come-along. Solution: Make a "Spanish windlass.
Solution: Make a “Spanish windlass.” Pass a length of rope around both objects and tie the ends together. Place a bar or handle through the center of the loop and twist the opposite sides together. The twisted rope creates considerable pulling force for a short distance.
Contributor: D.E. Burgess, Phoenix, AZ
