Thread sealant
The Loctite 5452 is specifically formulated for use on metal fittings found in high pressure hydraulic and pneumatic power systems. Curing four times faster than traditional anaerobic sealants even on stainless steel or inert metals, the 5452 sealant allows fittings under low pressure to be returned to service immediately.
The Loctite 5452 is specifically formulated for use on metal fittings found in high pressure hydraulic and pneumatic power systems. Curing four times faster than traditional anaerobic sealants even on stainless steel or inert metals, the 5452 sealant allows fittings under low pressure to be returned to service immediately. This sealant contains no fillers or particles that could contaminate system fluids, foul valves or clog fine filters/screens. The sealant withstands operating temperatures from -65°F to 300°F and resists pressures to 10,000 psi.
Henkel www.henkelna.com
