Thin coat protects aluminum
Tufram 2000, available in sealed and unsealed versions, gives aluminum surfaces resistance to corrosion and provides good wear. The consistently uniform surface, applied in a thickness of 0.0005-0.0007 in.
By Staff March 1, 2000
Tufram 2000, available in sealed and unsealed versions, gives aluminum surfaces resistance to corrosion and provides good wear. The consistently uniform surface, applied in a thickness of 0.0005-0.0007 in., makes it useful for close tolerance applications, such as screw threads. Thickness is customized for each application, and coated parts retain the thermal conductivity of aluminum.
General Magnaplate Corp.
www.magnaplate.com
Circle 277
