Thermometer/scanner
Energy Audit IR Thermometer/Scanner with Star Burst Laser Targeting (IRTC50) designates a set point and determines whether subsequent readings are within or outside selectable ranges from that set point
May 4, 2011
The new Energy Audit IR Thermometer/Scanner with Star Burst Laser Targeting (IRTC50) allows the user to designate a set point and determine whether subsequent readings are within or outside selectable ranges from that set point. The Star Burst laser targeting system lets the user easily determine the area being measured. The device is ideal for conducting energy audits; it can perform a progressive scan over a pre-determined area and check for temperature differentials. It also has a wide variety of applications for HVACR technicians, building inspectors, electricians, plumbers, manufacturing technicians, homeowners and others. The precision point-and-shoot IR Thermometer/Scanner easily and safely scans and measures surface temperatures without requiring direct contact to inaccessible or dangerous objects.
General Tools and Instruments
www.generaltools.com
