Thermal fluid takes more heat
By Staff January 1, 2000
Dowtherm MX synthetic, aromatic-based heat transfer fluid provides long-term thermal stability and performance in zero pressure, liquid-phase systems that typically use higher performing hot oils for heat transfer at temperatures beyond hot oil temperature ranges. The fluid operates well in low-pressure systems between 550-620 F.
The Dow Chemical Co.
Circle 372
