Continue to Site
The six fault zones key to proper maintenance
A proper maintenance program goes beyond a visual inspection; instead it uses the proper tools and equipment necessary to check the six fault zones of a motor.
By David Manney, L&S Electric October 18, 2017
Establishing a routine maintenance program is the best way to ensure that your electric motors and other equipment will operate when you need them. The maintenance program must go beyond a visual inspection of the equipment. It needs to use the proper tools and equipment to both test and analyze your motors. Keeping a close tab on the motors is important, they have an impact on all equipment associated with them.
The six fault zones
Tests included in your maintenance program should assess the following six fault zones, which indicate the overall health of the motor:
1. Power circuit
Power circuit relates to the various components and connections that are downstream from the motor’s location, including fuses and circuit breakers, overloads, lug connections, disconnects, and contactors. It is possible to analyze the power circuit by measuring its health.
2. Power quality
To test power quality, consider both the current and the voltage. This fault zone comes from the electrical system, and when problems occur, they result in damage to the motor immediately or over time. Check the power quality by testing the crest factor, total RMS voltage, current harmonic voltage, and average voltage.
3. Rotor
There are several issues associated with the rotor fault zone. These include rotor laminations, bars, and end rings. It is unlikely that rotor faults result in direct issues with the motor, but they do cause parts of the motor to experience problems and eventually fail. Some of the tests for this zone include current demodulation, inductive imbalance, and inrush current.
4. Stator
The connections of the internal coil to the turn-to-turn insulation are associated with the stator fault zone. The tests in this region include analyzing inductive or impedance imbalances.
5. Insulation
Motor insulation is responsible for keeping different parts of the motor separated from each other. Heat has an adverse impact on insulation and significantly reduces the lifespan of the motor. Keeping the motor allows the insulation to do its job. In turn, this helps protect the windings and allows the motor to operate indefinitely. Other issues that affect the insulation include vibration, moisture, and contamination. Regular testing of the insulation indicates the overall health of the motor.
6. Air gap
The gap between the stator and the rotor is the air gap zone. Two types of faults exist in the air gap: dynamic and static. Analyze the air gap area by using a rotor influence check test (RIC) and current signature analysis.
These steps should be part of a routine maintenance program. Be sure that you are not just looking things over. Instead, use proper testing equipment to examine the six fault zones, which shows you just how healthy your motor is.
David Manney is marketing administrator at L&S Electric. This article originally appeared on Watts New L&S Electric’s blog. L&S Electric is a CFE Media content partner.
Original content can be found at lselectric.com.
