Tees for joining black iron pipe
Reducing tee configurations for the MegaPress and MegaPressG system for joining schedule 5 to schedule 40 black iron pipe in sizes 1/2 to 2 in.
Viega’s reducing tee configurations for the MegaPress and MegaPressG system for joining schedule 5 to schedule 40 black iron pipe in sizes 1/2 to 2 in. The MegaPress system uses cold press connections for pipe installation and is designed for hydronic heat, chilled water, compressed air, fire sprinkler systems, low pressure steam, and vacuum lines. MegaPressG fittings are designed for use in fuel oil and natural gas applications. MegaPress fittings include elbows, couplings, reducers, tees, reducing tees, threaded adapters, caps, flanges, and unions. The fittings use a stainless steel grip ring with an EPDM sealing element along with a stainless steel separator ring.
Viega
