System tests lines up to 10,000 psi
Check System is a series of diagnostic test points, adapters, and MicroFlex hoses that connect and disconnect under pressures up to 10,000 psi in systems using fluid or gas media.
Check System is a series of diagnostic test points, adapters, and MicroFlex hoses that connect and disconnect under pressures up to 10,000 psi in systems using fluid or gas media. Micro-poppet design allows local pressure measurements to be made by hand without interrupting machine operation.
Schroeder Industries
