System guards against premature bearing failure
AquaGard system combines a seal with a moisture warning or control device to continually and actively protect rotating equipment against moisture damage to bearings and lubricants.
AquaGard system combines a seal with a moisture warning or control device to continually and actively protect rotating equipment against moisture damage to bearings and lubricants. AquaChek version provides advance notice of unsafe moisture levels by using a contact-design bearing isolator. AquaDri product excludes dust and removes excess moisture to extend the life of rotating equipment.
JM Clipper/Trico Mfg. Corp.
Circle 381
