Switch for precision flow, level, temperature
The FLT93 Series FlexSwitch can be used in a wide range of fluids and industrial applications.
The new design of the FLT FlexSwitch features a quick disconnect terminal block. The electronics assembly is firmly secured into an aluminum or stainless steel housing. The dual-function FLT93 switches can be configured for flow or level sensing, flow + temperature sensing or level + temperature sensing. Dual trip points and 6A relay outputs are standard and are assignable to flow, level or temperature. Both sensing elements can be supplied in either standard (-40 to 350°F [-40 to 177°C]) or medium (-100 to 500°F [-73 to 260°C]) temperature configurations. The electronic control circuit can be integrally-mounted with the sensing element, or it can be located in a remote location.
Fluid Components International
