Switch customizes high/low readings
F7-MLK multilevel switch contains all the components needed to fabricate a one or two-station level switch for vertical pipe plug mounting.
F7-MLK multilevel switch contains all the components needed to fabricate a one or two-station level switch for vertical pipe plug mounting. The kit includes two level stations (switch, tube, and Buna-N float), brass extension tubes, tube unions, end fitting, and mounting plug.
Dwyer Instruments, Inc.
Circle 403
