Surge protective devices (SPDs)
PowerSure CM Series
The PowerSure CM Series surge protective devices (SPDs) are designed to help prevent electric power line disturbances from disrupting or damaging sensitive electronic equipment. These compact AC power surge protectors are rated at 50kA per mode and housed in a weather-resistant (UL Type 4X) enclosure, so they can be installed virtually anywhere in the customer’s electrical system. An optional DIN rail mounting assembly allows customers to install the PowerSure CM Series on standard 35mm industrial DIN rails. It can also be screw-mounted. The PowerSure CM Series also features remote indication of protection status via both LEDs and summary alarm contacts.
Emerson Network Power
www.emersonnetworkpower.com
