Suggestions & Solutions
By Staff December 1, 2001
How clean I am
How to Filter Compressed Air , Bulletin 120, is a free, 16-p booklet that uses text and illustrations to describe types of compressed air filters, guidelines for selecting the correct filter for a particular application, and other helpful information.
Deltech
deltech-flair.com
Write 251 on PE card
Gas engine reduces emissions
Brochure introduces a line of lean-burn gas engine/generator sets for prime and peaking power applications. Sized form 334 kW to 1.75 MW, these generator sets are powered by fuel-efficient, spark-ignited engines that reduce NO x emissions.
Cummins Power Generation
cumminspowergeneration.com
Write 252 on PE card
Pumps on CD-ROM
A 2 CD-ROM set of the Goulds Pump Manual includes the 8thissue of the GPM catalog and the Goulds Pump Selection System. The set makes it possible to click-through the pump catalog, and make selections by the use of electronic tools.
I TT Industries, Goulds Pumps
gouldspumps.com
Write 253 on PE card
Recorders track overheating
Temp-Plate irreversible temperature recorders provide a low-cost alternative to monitoring surface temperatures with sensors or probes. These versatile, inexpensive, miniature labels create a permanent record of overheat conditions.
Wahl Instruments, Inc.
instrumentationgroup.com
Write 254 on PE card
