Submersible pressure transmitters for Class I, Div. 1
Submersible pressure transmitters are optimized for detecting the level of water or other media with similar density in challenging industrial environments including wastewater and irrigation systems and tanks containing liquids such as gas and diesel.
October 27, 2009
TURCK PT4500 Sensor
The PT4500 and PT4510 submersible pressure transmitters are
systems and tanks containing liquids such as gas and diesel. The PT4510
submersible pressure transmitter was designed for low-level applications of up
to 400 inches; the PT4500 is available in ranges up to 100 psig.
To deliver accurate level detection, a transmitter is placed
at the bottom of the tank holding the liquid, and the transmitter then converts
the pressure reading to an analog 4-20 mA output signal. The electrical
connection to the transmitter is routed through the top of the tank and
contains power and signal wires. It additionally includes a breathing tube that
is used as a reference port to determine the atmospheric pressure outside of
the tank.
These IP68-rated, stainless steel pressure transmitters may
be used in industrial applications, as well as hazardous classified areas. The
transmitters carry UL/cUL 913 approval for use in Class I, Division 1, Groups C
and D locations when installed with an approved barrier.
TURCK
www.turck.us
