Stainless-steel servo-rated gearheads
Available in planetary and right-angle models, stainless-steel, servo-rated gearheads are specifically designed for use with its stainless-steel servo motors. Capable of handling IP66 and 1,500-psi washdown conditions, the gearheads are designed with low backlash to reduce shock loads in dynamic applications.
By Staff November 1, 2006
Available in planetary and right-angle models, stainless-steel, servo-rated gearheads are specifically designed for use with its stainless-steel servo motors. Capable of handling IP66 and 1,500-psi washdown conditions, the gearheads are designed with low backlash to reduce shock loads in dynamic applications. Features include an integrated, self-locating input coupling to ease assembly.
Baldor Motion Products : www.baldor.com
