Stainless steel flat nozzle
The Stainless Steel Flat Super Air Nozzle, with its flat 1" (25mm) wide airstream with a strong blowing force of 16 ounces and stainless steel construction makes it ideal for corrosive, high temperature, food, pharmaceutical, and chemical environments.
By CFE Media October 1, 2014
The new 1" High Power Stainless Steel Flat Super Air Nozzle produces a flat 1" (25mm) wide airstream with a strong blowing force of 16 ounces (462g) when mounted 12" (305mm) from the target. Its design and stainless steel construction makes it ideal for corrosive, high temperature, food, pharmaceutical, and chemical environments.
It also adheres to OSHA dead end pressure standard CFR 1910.242(b), meets OSHA noise exposure standard 29 CFR 1910.95(a) (82 dBA) and is constructed of zinc aluminum alloy construction, suitable for rugged industrial applications.
Exair
www.exair.com/1hpsanss.htm
Author Bio: Since its founding in 2010, CFE Media and Technology has provided engineers in manufacturing, commercial and industrial buildings, and manufacturing control systems with the knowledge they need to improve their operational efficiency. CFE delivers the right information at the right time around the world through a variety of platforms.
