Stainless-steel compression fittings
By Plant Engineering Staff September 29, 2006
Grip-Seal fittings are designed for quick installation, are reusable and require no open flame or special tools, and they have no crevices where fluid can stagnate. Fluid contacts only a Teflon seal in straight fittings and only a Teflon seal or 316-SS in elbows and tees. Grip-Seal fittings have a 100% full-flow area, the company states. Grip-Seal stainless steel coupling, tee and 90° elbow compression pipe and tube fittings are available in a selection of sizes for both IPS pipe and OD tubing. Sizes range from 1/4 to 4 inches for IPS and 1/2 to 2 inches for OD. Pressure ratings vary with size.
Jaeco Fluid Systems
www.jaecofs.com
