Spray run
The CU150A spray gun from Spraying Systems Co. is a low pressure spray gun ideal for cleaning and sanitizing applications. It provides precise control and is lightweight and designed to reduce operator fatigue. It also offers a variable spray pattern, and interchangeable orifice caps that are corrosion-resistant.
By Staff October 1, 2005
The CU150A spray gun from Spraying Systems Co. is a low pressure spray gun ideal for cleaning and sanitizing applications. It provides precise control and is lightweight and designed to reduce operator fatigue. It also offers a variable spray pattern, and interchangeable orifice caps that are corrosion-resistant. All components are user serviceable.
Spraying Systems Co. www.spray.com Write 309 on PE card
