Spray helps mount/dismount bearings
Freeze Spray instantly freezes bearings and gears to -60 F, which helps mount and dismount interference fit mechanical components without damaging surface finishes.
Freeze Spray instantly freezes bearings and gears to -60 F, which helps mount and dismount interference fit mechanical components without damaging surface finishes. The aerosol coolant system can also be used to help locate thermal intermittent component failures and shorts in electrical circuits. The spray is nonflammable, nonabrasive, plastic safe, and leaves no residue.
CRC Industries, Inc.
Circle 385
