Continue to Site
Software provides automation solutions
ProcessPak software is programmed using a function block technology based on RSLogix Frameworks. This arrangement allows users to graphically program systems, eliminating the need to address every programmed instruction.
By Staff December 1, 1998
ProcessPak software is programmed using a function block technology based on RSLogix Frameworks. This arrangement allows users to graphically program systems, eliminating the need to address every programmed instruction. Frameworks uses function block programming — a set of instructions contained in a graphic block that can be connected to other blocks to form a program.
Rockwell Automation
ww.rockwellautomation.com
