Sine wave inverter fits in 1U rack
This 3 kVA pure sine wave inverter provides clean output power for sensitive loads and includes an automatic bypass switch.
By Plant Engineering Staff February 24, 2009
The AEP-A3000R series is a 3 kVA pure sine wave inverter packaged in a 1U rackmount design. Compared to quasi-sine wave units, the inverter provides clean output power for sensitive loads and improving ac equipment performance. The inverter family is available in three standard input configurations of 12 Vdc, 24 Vdc and 48 Vdc. Outputs are available in 115 or 230 Vac (50/60 Hz) versions, which are regulated to +/-3% or better. A built-in, 4-6 millisecond automatic bypass switch allows redundant operation from utility power if the dc supply drops out. All models in the series feature circuit and overload protection with digital displays and alarms to indicate low input voltage, short circuit, input overvoltage, over temperature, overload and low battery. The display also indicates voltage, current, power and temperature.
Schaefer Inc. www.schaeferpower.com
