Short-body inductive proximity sensors
PN series inductive proximity sensors are IP 69K-rated short-body sensors with metal housings.
By AutomationDirect February 16, 2015
The PN series inductive proximity sensors are IP 69K-rated short-body sensors with metal housings. These three-wire 10-30 VDC sensors are equipped with LED status indicators and are available with an attached two-meter output cable or M12 quick-disconnect. All styles are available with shielded or unshielded housings as well as normally-open or normally-closed and PNP or NPN output types. PN series sensors are CE and RoHS approved; sensors with M12 quick disconnects are cULus approved and sensors with two-meter cables are UL approved.
AutomationDirect
www.automationdirect.com
